Have you looked at the waveform/changed load type/changed counter settings to verify that the 16kHz is actually what's coming out?
It's pretty unusual to be that far off and not be a multiple of the frequency or something - I suspect the 16kHz you're measuring is an artifact from the combination of measurement/output settings or a symptom of a different fault.
