In that case you can try to reverse engineer that PCB with the burnt resistor and create a schematic.
Using this schematic, you can try and find possible values for that resistor.
ei:
If it's a pulldown resistor for a FET, generally nearly any resistor value between 10k and 50k would work fine.
If it's a voltage divider that's meant to create a specific voltage, and you know that specific voltage it should output, you can calculate the value of the resistor.
etc...
Make an educated guess and choose the largest value and go down from there. Largest, to smallest resistance value.
