Author Topic: Tektronix Cabinet Paint  (Read 2917 times)
Offline Ground_LoopTopic starter
« on: November 22, 2020, 12:57:49 pm »
I have a working 555 that needs some cosmetic work. Do any of you know of a paint code for the cabinet.
There's no point getting old if you don't have stories.
Online Alex Eisenhut
  • Place text here.
Re: Tektronix Cabinet Paint
« Reply #1 on: November 22, 2020, 04:42:01 pm »
Apparently the Tektronix part number for a can of Tek blue spray paint is 252-0092-02. You could still order them up to 2005.
I don't know about today.
There are also many archived discussions in tekscopes.
https://groups.io/g/TekScopes/topic/72377540#165206
That is the place to check!
The following users thanked this post: coromonadalix
Offline PaulAm
« Reply #2 on: November 23, 2020, 01:36:14 am »
Take a panel down to your local Sherwin-Williams or Benj Moore paint store and see if they can match up a low luster enamel.  Probably the easiest and cheapest route.
Auto paint stores might be another option.
One problem I've had with custom color matching is they won't mix up less than a gallon (in the bad old days when nobody cared about VOCs, you could get a quart of lacquer mixed up for under $20)
« Reply #3 on: November 23, 2020, 02:32:04 am »
med5763 in the US uses Krylon Gloss Bahama Sea aerosols as a Tek blue equivalent.
He even sprayed an old Heathkit scope with it !  :-DD
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg2427270/#msg2427270
Med took a pic:
« Last Edit: November 23, 2020, 06:29:59 am by tautech »
« Reply #4 on: November 23, 2020, 03:11:35 am »
Thanks for the replies. I've seen a number of substitutes flying around, but was hoping for the real deal. Anyway, I'm not making a certified restoration so close will be good enough.
Online notsob
« Reply #5 on: November 23, 2020, 03:15:22 am »
A pantone number would be great if anyone has it
The following users thanked this post: walter.aranda
  • Place text here.
« Reply #6 on: November 24, 2020, 12:15:45 am »
Oh the can I pictured is the real deal, that's what I got from Tektronix with that part number. Apparently you can call the number on the can to order that directly. It's the number for Sherwin Williams.
Offline walter.aranda
  • Country: br
« Reply #7 on: January 25, 2023, 12:19:40 am »
I think it is:
RGB: (82,122,138)
Pantone 2179 C
Hex: #527A8A
Offline Wallace Gasiewicz
« Reply #8 on: January 25, 2023, 12:28:12 am »
I think someone on the tekscopes group.io had some made up a while back and there was something like a group buy.
Maybe ask on that Group.
https://groups.io/g/TekScopes/messages
Online KE5FX
    • KE5FX.COM
« Reply #9 on: January 25, 2023, 04:38:59 am »
Also see previous thread.  Williamsburg Blue is the color name that I've always heard, but a search doesn't reveal much except threads like these.
Offline Paceguy
« Reply #10 on: January 27, 2023, 10:07:13 pm »
I have bought the Tektronix spray paint back in the 90's. I also have purchased and used the Krylon Bahama Sea blue. The Krylon is more glossy, but the color is a perfect match. It all depends on your finish preference, matte or glossy.
