Author Topic: Yamaha RX-V473 repair. PS3 PRT: 094L [SOLVED]  (Read 1191 times)
Offline Comp_Sci_haterTopic starter
Re: Yamaha RX-V473 repair. PS3 PRT: 094L
« Reply #25 on: September 07, 2024, 10:56:02 am »
You're right, i measured the voltages on the IC25 and they are as follows:
PIN NR     PIN         EXPECTED     MEASURED
    4          VDD               5.5V            5.57V
    3          VOUT             3.3V             5.44V
    2          GND               0V               0V
    1          CE/CE             5.5V            5.57V
Is the ic gone? there is no input apart from 5.5V so something internally must be messed up i assume.
« Last Edit: September 07, 2024, 10:57:48 am by Comp_Sci_hater »
Offline David_AVD
« Reply #26 on: September 07, 2024, 11:48:37 am »
With the unit unplugged from the wall, measure from pin 3 to 4 of IC25 on the Ohms range of your meter.
« Reply #27 on: September 07, 2024, 11:56:24 am »
It jumps all over the place, it once reached 6M ohms and then started going down for some reason
« Last Edit: September 07, 2024, 12:00:39 pm by Comp_Sci_hater »
« Reply #28 on: September 07, 2024, 05:37:55 pm »
Okay, im looking for a new regulator, i can get the original one but at an astronomical price. And im thinking that i dont really need a low dropout voltage one, because im supplying it with 5.5V anyway. Does anybody have a reccomendation for any good 3.3V regulators? Would a L1117-33 work well in this case?
« Last Edit: September 07, 2024, 05:48:57 pm by Comp_Sci_hater »
« Reply #29 on: September 16, 2024, 07:49:36 pm »
UPDATE: I replaced the 3.3V regulator and the amplifier works perfectly!  8) 8) 8)
The following users thanked this post: coromonadalix
