One unfortunate, and a fortunate thing happened today. The first one is that I dropped the best performing DM 501A in the batch (the only thing with zero reaction to input excitations was the DCA) on the floor (from my lap, so not a tall fall), and the second one is... I dropped etc. etc.
Initially, the plug seemed pretty shaken with zero readings on most inputs. After reading the manual (nth time) I had a hunch and reseated the display module and things came back to normal. By normal, I mean actually, everything works 95% now (all modes and ranges!...).
I regard this outcome being the result of:
- This is one that I both washed with IPA, and conditioned with David's recommended contact conditioner.
- The fall must've helped with whatever mechanical issue the DCA was inflicted with.
- This unit is one of two with the revision David mentioned being applied to the later units (and earlier ones that probably visited the Tek shop and had it applied, and I'm pretty sure the other one I have that has the revision is also my oldest unit).
Now, I'm saying 95% because there's a bit of "wander" of the indication of a measured value. It doesn't happen all the time, and when it does, I have to re-actuate the range switches (up-down-up...) to restore the correct indication of the meter. I'm tempted to blame this for some leftover flakiness of the switches. But I have a nagging gut feeling there's some flakiness of the input circuitry - maybe the multiplexer? - which creates or just adds to this wandering.
