Hi All,
Does anyone has HMS-X HMS 3010 analyser with tracking generator and would be able to measure how TG output, looks like?
I would expect sinusoidal waveform but now in user manual I see it is not needed.
Scope time waveform, power measured by another Spectrum Analyser -20,8dBm when setting output to -20dBm. Signal is distorted in 2 stage BF520 based RF amplifiers. It see proper sine waveform.
Voltage for TG block is enabled on screen and controlled by R103G33 LDO. LDO output voltage in tollerance 3.2... sth so should be fine. Thermal image does not lead to part which would be overheated.
