Hi all,
DPO4104 not leaving boot splash screen,
by reading the serial port (thank you!) I get as attached.
Does this sound familiar to anyone here?
Thank you very much in advance!
______________________________________________________
U-Boot 1.1.4 (Jan 8 2007 - 11:12:14) Tektronix, Inc. V1.06
CPU: AMCC PowerPC 440EP Rev. C at 333.333 MHz (PLB=133, OPB=66, EBC=66 MHz) I2C boot EEPROM enabled
Internal PCI arbiter enabled, PCI async ext clock used
32 kB I-Cache 32 kB D-Cache
Board: Tektronix Route66 IBM 440EP Main Board
<9>VCO: 666 MHz
<9>CPU: 333 MHz
<9>PLB: 133 MHz
<9>OPB: 66 MHz
<9>EPB: 66 MHz
I2C: ready
DRAM: 128 MB
FLASH: 64.5 MB
PCI: Bus Dev VenId DevId Class Int
00 13 10b5 9056 0680 18
00 15 1002 4c59 0300 17
DISP: Type 1
In: serial
Out: serial
Err: serial
Enter password - autobooting in 3 seconds
## Booting image at f0000000 ...
Image Name: Linux-2.4.20_mvl31-440ep_eval
Image Type: PowerPC Linux Multi-File Image (gzip compressed)
Data Size: 1441010 Bytes = 1.4 MB
Load Address: 00000000
Entry Point: 00000000
Contents:
Image 0: 1033953 Bytes = 1009.7 kB
Image 1: 407042 Bytes = 397.5 kB
Verifying Checksum ... OK
Uncompressing Multi-File Image ... OK
cmdline is console=ttyS0,9600 quiet bigphysarea=519 panic=2 root=/dev/mtdblock7 rw mem=131072k
Loading Ramdisk to 07f2b000, end 07f8e602 ... OK
Checking for firmware update...
No USB mass storage devices found to update from.
Linux 2.4.20_mvl31-440ep_eval V 1.15 Tektronix Route66 Tue Jun 22 15:19:50 PDT 2010
stat of /var/log/dmesg failed: No such file or directory
rm: cannot remove '/var/run/*': No such file or directory
Warning: loading NiDKEng-1.6 will taint the kernel: non-GPL license - Proprietary
See
http://www.tux.org/lkml/#export-tainted for information about tainted modules
Warning: loading NiDUsb-1.6 will taint the kernel: non-GPL license - Proprietary
See
Warning: loading tek will taint the kernel: non-GPL license - Proprietary
See
Scope application starting (normal mode)
---------------------- startScopeApp() running Init code ----------------------
versionBuildFWVersionString(): TimestampString: 25-Apr-12 11:13
VersionFIRMWAREVERSIONversion: v2.68
Major ver num: 2 Minor ver num: 68
Initializing Mia[0]<
<9>PA Bus error. Skipping initialization of devices on PA bus
Initializing Ibm440[0]
Initializing HFD204ADC[1]
Initializing HFD204ADC[0]
Model id: 0x03
Initializing Ltc1658Dac[0]
Board id: 0x01
Initializing M859[3]
Initializing M859[2]
Initializing M859[1]
Initializing M859[0]
HFD144[0] ID_REG = 0x00001440
HFD144[1] ID_REG = 0x00001440
HFD144[2] ID_REG = 0x00001440
HFD144[3] ID_REG = 0x00001440
Initializing Hfd144[0]
Initializing Hfd144[1]
Initializing Hfd144[2]
Initializing Hfd144[3]
<9>Open Max5362 successful.
Initializing Max5362[0]
Initializing Ltc1661Dac[1]
Initializing Ltc1661Dac[0]
hwInit failed
Init ADT7468 and locking.
Factory Checksum: Stored: 41143, Calculated: 41143 - OK
Spc CheckSum: stored: 37628 calculated: 37628 - OK
