At work we have a Tek DPO3034 (hacked to 3054), that fails SPC.
The instrument has a serial starting with C01XXXX, on which the software bandwidth upgrade is not working theoretically, but in our case it did.
In fact after the hack the SPC still ran fine, until one point, but not anymore. There haven't been any noticeable event to the scope why it shouldn't work, and indeed the scope works quite well as far as I can tell, but it fails SPC.
Now, running SPC from the scope UI does not tell much information why is it not passing. Is there any way to see a detailed log at which step the procedure fails?
