After a long break I reinvested some time in my broken scope and a new hot air station. I reflowed U370 and something changed.
U-Boot 1.1.4 (Jan 8 2007 - 11:12:14) Tektronix, Inc. V1.06
CPU: AMCC PowerPC 440EP Rev. B at 333.333 MHz (PLB=133, OPB=66, EBC=66 MHz)
I2C boot EEPROM enabled
Internal PCI arbiter enabled, PCI async ext clock used
32 kB I-Cache 32 kB D-Cache
Board: Tektronix Route66 IBM 440EP Main Board
VCO: 666 MHz
CPU: 333 MHz
PLB: 133 MHz
OPB: 66 MHz
EPB: 66 MHz
I2C: ready
DRAM: 128 MB
FLASH: 64.5 MB
PCI: Bus Dev VenId DevId Class Int
00 13 10b5 9056 0680 18
00 15 1002 4c59 0300 17
DISP: Type 1
In: serial
Out: serial
Err: serial
Enter password - autobooting in 3 seconds
## Booting image at f0000000 ...
Image Name: Linux-2.4.20_mvl31-440ep_eval
Image Type: PowerPC Linux Multi-File Image (gzip compressed)
Data Size: 1441010 Bytes = 1.4 MB
Load Address: 00000000
Entry Point: 00000000
Contents:
Image 0: 1033953 Bytes = 1009.7 kB
Image 1: 407042 Bytes = 397.5 kB
Verifying Checksum ... OK
Uncompressing Multi-File Image ... OK
cmdline is console=ttyS0,9600 quiet bigphysarea=519 panic=2 root=/dev/mtdblock7 rw mem=131072k
Loading Ramdisk to 07f2b000, end 07f8e602 ... OK
Checking for firmware update...
No USB mass storage devices found to update from.
Linux 2.4.20_mvl31-440ep_eval V 1.15 Tektronix Route66 Tue Jun 22 15:19:50 PDT 2010
stat of /var/log/dmesg failed: No such file or directory
Warning: loading NiDKEng-1.6 will taint the kernel: non-GPL license - Proprietary
See [url]http://www.tux.org/lkml/#export-tainted[/url] for information about tainted modules
Warning: loading NiDUsb-1.6 will taint the kernel: non-GPL license - Proprietary
Warning: loading tek will taint the kernel: non-GPL license - Proprietary
See [url]http://www.tux.org/lkml/#export-tainted[/url] for information about tainted moScope application starting (normal mode)
---------------------- startScopeApp() running Init code ----------------------
versionBuildFWVersionString(): TimestampString: 25-May-11 15:07
VersionFIRMWAREVERSIONversion: v2.58
Major ver num: 2 Minor ver num: 58
Initializing Mia[0]
Adg523 detected, patching reg offsets
Initializing Tek0005[0]
Initializing Ibm440[0]
Initializing HFD204ADC[1]
Initializing HFD204ADC[0]
Model id: 0x02
Initializing Ltc1658Dac[0]
Board id: 0x00
Initializing M859[3]
Initializing M859[2]
Initializing M859[1]
Initializing M859[0]
HFD144[0] ID_REG = 0x00001440
HFD144[1] ID_REG = 0x00001440
HFD144[2] ID_REG = 0x00001440
HFD144[3] ID_REG = 0x00001440
Initializing Hfd144[0]
Initializing Hfd144[1]
Initializing Hfd144[2]
Initializing Hfd144[3]
Open Max5362 successful.
Initializing Max5362[0]
Initializing Ltc1661Dac[1]
Initializing Ltc1661Dac[0]
Init ADT7468 and locking.
CANNOT SET FAN PARAMETERS - CONTROLLER LOCKED
Factory Checksum: Stored: 36701, Calculated: 36701 - OK
Spc CheckSum: stored: 24980 calculated: 24980 - OK
Demux initialization
Dram calibration
dmx 03 ERROR: 06_calDriveStrength: didn't find good value for DramDqPullUpStrength
ERROR: DramDqPullUp can not pull up.
Bit Fields A - H: (All bytes would be 0xff for a good cal.
0xff 0xff 0xf7 0xf7 0xff 0xff 0xff 0xff
dmx 03 ERROR: 06_calDriveStrength: didn't find good value for DramDqPullDownStrength
ERROR: DramDqPullDown can not pull down.
0x0 0x0 0x0 0x3 0x0 0x0 0x0 0x0
dmx 03: DramCal FAILED *****
Dram calibration complete
Dram Calibration results:
dmx 02: PASSED
dmx 03: FAILED *****
Demux initialization complete
Starting POST diags
Diag Failure: Mode 100 4, U370,U480,U0471,U470,U0462, 0x00000000 0x00000001 0x00000001
Diag Failure: Mode 100 4, U370,U480,U0471,U470,U0462, 0x00000000 0x00000002 0x00000002
Failure at address 0x0
Failure at address 0x10
Failure at address 0x20
Failure at address 0x30
Failure at address 0x40
Failure at address 0x50
Failure at address 0x60
Failure at address 0x70
Failure at address 0x80
Failure at address 0x90
Failure at address 0xa0
Failure at address 0xb0
Failure at address 0xc0
Failure at address 0xd0
Failure at address 0xe0
Failure at address 0xf0
Diag Failure: Mode 100 7, U370,U270, 0x0000ffff 0xffffffff 0xffff0000
Diag Failure: Mode 100 7, U370,U270, 0x00000000 0x0000ffff 0x0000ffff
Diag Failure: Mode 100 7, U370,U270, 0x0000fefe 0xfefeffff 0xfefe0101
Diag Failure: Mode 100 7, U370,U270, 0x00000101 0x0101ffff 0x0101fefe
Diag Failure: Mode 100 7, U370,U270, 0x0000fdfd 0xfdfdffff 0xfdfd0202
Diag Failure: Mode 100 7, U370,U270, 0x00000202 0x0202ffff 0x0202fdfd
Diag Failure: Mode 100 7, U370,U270, 0x0000fbfb 0xfbfbffff 0xfbfb0404
Diag Failure: Mode 100 7, U370,U270, 0x00000404 0x0404ffff 0x0404fbfb
Diag Failure: Mode 100 7, U370,U270, 0x0000f7f7 0xf7f7ffff 0xf7f70808
Diag Failure: Mode 100 7, U370,U270, 0x00000808 0x0808ffff 0x0808f7f7
Diag Failure: Mode 100 7, U370,U270, 0x0000efef 0xefefffff 0xefef1010
Diag Failure: Mode 100 7, U370,U270, 0x00001010 0x1010ffff 0x1010efef
Diag Failure: Mode 100 7, U370,U270, 0x0000dfdf 0xdfdfffff 0xdfdf2020
Diag Failure: Mode 100 7, U370,U270, 0x00002020 0x2020ffff 0x2020dfdf
Diag Failure: Mode 100 7, U370,U270, 0x0000bfbf 0xbfbfffff 0xbfbf4040
Diag Failure: Mode 100 7, U370,U270, 0x00004040 0x4040ffff 0x4040bfbf
Diag Failure: Mode 100 7, U370,U270, 0x00007f7f 0x7f7fffff 0x7f7f8080
Diag Failure: Mode 100 7, U370,U270, 0x00008080 0x8080ffff 0x80807f7f
Diag Failure: Mode 100 8, U271, calloc failed, 0
Finished POST diags
Class 2 Level 2 acq error from sysTaskCreate in acqInit 0
01:11:45 Fri Apr 26 2024 (thread: tUsrRoot)
Class 2 Acquire Id 99 Instance 0 Severity 2 01:11:45 Fri Apr 26 2024 (thread: tUsrRoot) file errPublic.c line 663 (null)
errAddErrorLogDataEntry: sysAppState != SYS_STATE_ACTIVE
Class 2 Acquire Id 4 Instance 0 Severity 1 01:11:45 Fri Apr 26 2024 (thread: tUsrRoot) file acqPublic.c line 483 (null)
All tasks suspended by errLogDataMsg call from tUsrRoot
errSuspendAll called from tUsrRoot
Backtrace: (depth of 6 shown)
/usr/local/bin/scopeApp.ppcep(errSuspendAll+0x6c)[0x10c40f74]
/usr/local/bin/scopeApp.ppcep(errLogDataMsg+0x3d0)[0x10c3f8c4]
/usr/local/bin/scopeApp.ppcep(errLogMsg+0x5c)[0x10c3f944]
/usr/local/bin/scopeApp.ppcep(_Z8acqErroriiiiPci+0xbc)[0x1039c790]
/usr/local/bin/scopeApp.ppcep(_Z7acqInitv+0x3b0)[0x1039ba24]
/usr/local/bin/scopeApp.ppcep[0x10c52628]
Class 22 System Id 0 Instance 22 Severity 2 01:11:45 Fri Apr 26 2024 (thread: tUsrRoot) file sysError.c line 191 (null)
cmdParmGetIntMsgPoll() error processing cmd for parm 151, clientId: 0, retCode: -1
System status:
SheetMemSize=0, TotalNumSheets=0, bus state=-1, xop state=0
MeasAbort=0, MathAbort=0
CurrentTransactionState=-1, CurrentTransactionParm=Invalid parm id
CurrentTransactionType=-1, arg1Type=0, arg2Type=0
Sys tasks and their state:
Name TaskId Pri Pipe Msgs/Max Handler
ext 0 n/a n/a
errSuspendAllThread(): could not suspend fpIntTask, retCode = -1
errSuspendAllThread(): could not suspend fpUnloadCmdQueueThread, retCode = -1
errSuspendAllThread(): could not suspend fpIrqMonitor, retCode = -1
errSuspendAllThread(): could not suspend usbHotplug, retCode = -1
errSuspendAllThread(): could not suspend UsbOutputMgr, retCode = -1
errSuspendAllThread(): could not suspend piUsb, retCode = -1
errSuspendAllThread(): could not suspend piVGpib, retCode = -1
errSuspendAllThread(): could not suspend probesSharedUnloadCmdQueueThread, retCode = -1
errSuspendAllThread(): could not suspend autoset, retCode = -1
errSuspendAllThread(): could not suspend cal, retCode = -1
errSuspendAllThread(): could not suspend diag, retCode = -1
errSuspendAllThread(): could not suspend fp, retCode = -1
errSuspendAllThread(): could not suspend hc, retCode = -1
errSuspendAllThread(): could not suspend UsbSicInputMsgMgr, retCode = -1
errSuspendAllThread(): could not suspend wfmMgrTest, retCode = -1
errSuspendAllThread(): could not suspend search, retCode = -1
errSuspendAllThread(): could not suspend periodicZoom, retCode = -1
errSuspendAllThread(): could not suspend periodicClockAnimation, retCode = -1
errSuspendAllThread(): could not suspend periodicBusyIndicAnimation, retCode = -1
errSuspendAllThread(): could not suspend math, retCode = -1
errSuspendAllThread(): could not suspend meas, retCode = -1
errSuspendAllThread(): could not suspend measImmed, retCode = -1
errSuspendAllThread(): could not suspend piCmdIntfc, retCode = -1
errSuspendAllThread(): could not suspend ref, retCode = -1
errSuspendAllThread(): could not suspend rtl, retCode = -1
errSuspendAllThread(): could not suspend tHttpd, retCode = -1
errSuspendAllThread(): could not suspend tVxi11SRQd, retCode = -1
errSuspendAllThread(): could not suspend tVxi11Rpcd, retCode = -1
errSuspendAllThread(): could not suspend bus, retCode = -1
errSuspendAllThread(): could not suspend mitlRb, retCode = -1
errSuspendAllThread(): could not suspend VgpibRead, retCode = -1
errSuspendAllThread(): could not suspend VgpibWrite, retCode = -1
errSuspendAllThread(): could not suspend tSocketServerService, retCode = -1
errSuspendAllThread(): could not suspend tSocketResponseThread, retCode = -1
errSuspendAllThread(): could not suspend UsbTmcEventDispatcher, retCode = -1
errSuspendAllThread(): could not suspend inputOverload, retCode = -1
errSuspendAllThread(): all threads in list suspended
errSuspendAll(): TASK tUsrRoot SHOULD NOT BE HERE!!!
