TekScope software cannot be loaded onto this unit.
Contact your nearest Tektronix Support Center for assistance.
This software is intended for use on Tektronix DPO/MSO5000,
DPO7000C or DPO/DSA/MSO70000C Series oscilloscopes only.
Setup cannot continue.
This software is intended for use on Tektronix DPO/MSO70000DX
This software is intended for use on Tektronix DPO/MSO5000,(Same message as the one from the 2nd download link above.)
Can you show us a photo of the label of the HDD?I am not able to upload images directly. I am guessing it is because I am a new user here. I used postimg.cc; let me know if there are any issues seeing the images.
Can you dump the drive's 512-byte Identify Device data block using a tool such as CrystalDiskInfo? You need to select this option from the menu.
in device manager do you have exclamation(s) mark
serial number: 101118PBPB18FCC8NAKF
firmware version: PBBOC64G
model number: Hitachi HTS545016B9A300<17 spaces>
TEKUTI
VID 0699
PID FFFEi have some iso's of the 5k series i could search in them ... not at home ill update this thread if i find them later
"TEKUTI" became:
Tektronix USB-THC Instrument
Device Driver Installation Disk for Tektronix USB-TMC Instrument Device
Tektronix USB instruments use and require a generic USB Device Driver, referred to as a USB Test & Measurement Class driver or USBTMC driver. USBTMC is a subclass of the USB specification. This driver is typically included with the Virtual Instrument Software Architecture (VISA). (See block diagram below.)
For Tektronix oscilloscopes, this driver is included with TekVISA.
dir c:\ /s /b > filelist.txtmanaged to extract from a ghost file, not sure if it non B or BIt seems that your files have disappeared. I was not able to download unfortunately.
267 mb https://file.io/SdVquBsDRIJS (https://file.io/SdVquBsDRIJS)
as a follow up, do you still have errors in device manager ?There are no errors in Device Manager at all now.
Hi spymac,That looks promising. The original hard drive was 160 GB, and the disc says "for 500 GB hard drives". I could put in a 500GB hard drive but it makes me worry why it says that! Are there ISOs of these discs anywhere? I am guessing it is OK to share those because vanilla Windows 7 ISOs have been available for download directly from Microsoft.
I think this is what you need:
https://www.ebay.com/itm/125811662519 (https://www.ebay.com/itm/125811662519)
Calibrationfixture
