I remember reading about people using an HDMI cable or making their own cable using thin coaxial cables like RG-174 or RG-178 and flexible heat shrink.
HDMI sounds like an interesting idea, especially since they exist in much more flexible form than vga. I'll definitely be looking into that.
Do you have any way of detecting where the breaks are?
I don't really have any tdr equipment (or idea how I could set it up with the stuff I have
), but I tried both flexing it as well as a frequency sweep but both gave inconclusive results. Especially the flexing seems to suggest breaks at multiple locations within the cable.
But I'll just try cutting a bit off of the side in the amplifier, maybe I get lucky. Worst case I have to throw away the cable, which I wanted to do anyway
The probes are often damaged as even a few cm fall on a hard floor can chip or harline crack the fettire split cores.
I sure don't hope that's the case. The dumpster was at least padded with a ton of IGBTs and capacitors, maybe they softened the fall
Thanks for the tips, I'll report back once I decided what way I'll go with the repair
