After receiving an 8KV pulse (accidentally) during a measurement, not only the probe is broken, but also one of the input attenuator boards.
The Probe is mostly fine, except for the input chip resistor which actually has the resistive film (laser etched) on one side and an integrated capacitor in the other side of the ceramic substrate. The attached images show the resistor next to a 1206 SMD 000 jumper for size reference.
Well, the capacitor blew up (see the crater on the red paint) and left the resistor alone without compensation cap, leading the -3dB frequency to shrink from the original 200MHz to ~10KHZ
, so I have two choices:
1) To solder an SMD capacitor (probably ~10 pF) in parallel with the resistor
2) To get a spare resistor-capacitor chip
(and possibly a third choice: To buy a new probe
The resistor-capacitor chip seems to be a custom part, nearly impossible to source.
Suggestions ?
