Author Topic: Wavetek DM23XT not meausring  (Read 1591 times)
Offline blueagle91
« on: August 21, 2016, 01:06:29 pm »
Hello :)
So i have this old Wavetek andi used it a lot. Excelent DMM, not autorange but fast reliable, well reliable thats a question mark there isnt it :)
So bout a month ago, i just turned it on wanted to do some measurments, and well it wont measure. It stuck, it changes all the ranges, displays correct units, moves the decimal point, turns on off, changes AC DC, but it wont measure nothing.
For an example if i put it in diode/continuity check, its stuck at .220 and thats all. If i put it in MegaOhm range, it counts up like its charging a capacitor.
Volts are zero all the time. Anyone had this problem, fuses are ok, inputs do have nice clean contacts, probes are good.
I just hope its not something big, cause i really like it, i have other DMM`s, but i really love this one.
Thanks all the best
Offline retiredcaps
Re: Wavetek DM23XT not meausring
« Reply #1 on: August 21, 2016, 04:19:25 pm »
Can you post clear focused pictures of the pcb (both sides) so we can see the inside?  You may have a problem with one or more of the input protection components?
Offline Jacek_Paw
« Reply #2 on: August 22, 2016, 07:16:44 am »
I saw similar problem with Wavetek multimeter and it was caused by one of the traces under the knob. The material was to soft and it got pounded on the pcb and made a short with another trace. As far as I remember one of the traces was responsible for the reset and while it got shorted uC wasn't able to work.
