Thanks again. I'll ask a silly question, but that's the only way to learn. I've heard that these use odd tantalum caps that go bad, but I only really see 1 capacitor that looks like it is tantalum cap, and that's C3 which is part of the 5v regulator circuit. The rest seem to be radial electrolytic and ceramic caps. Am I missing something, or are there tantalum caps hiding in radial or ceramic-looking capacitor packages?
Mine seems to have 2 socketed 301A's for U55 and U155. A socketed 741 for U45 and the rest are soldered 751's. Also, there seem to be 3 ceramic caps soldered to the back, 2 33pF? (marked 33G) across the balance/compensation pins of the 301A's and another 47pF near U145 that I haven't traced. These don't seem to be on the schematic. Also they don't test well with my ESR meter and when I desolder them they don't read with a capacitance meter, so probably should replace them with new ceramics.
It seems you also have one of the 301A versions of the PS503A with the solid tantalum capacitors replaced with aluminum electrolytic capacitors and three ceramic capacitors on the back of the board. There is another circuit change on the front with an added resistor or capacitor. I have never seen a specific schematic for this version but the standard schematic is good enough.
The 301A operational amplifier requires external compensation so that is what the small ceramic capacitor under each of them is for. Internally compensated operational amplifiers like the 741 have this built in. You will need to put them back for proper operation.
Most ESR meters are not going to work on such small values of capacitance and tiny ceramic disk capacitor hardly ever fail.
The only solid tantalum capacitor on mine is at the output of the LM340T5 (practically the same thing as a 7805) regulator.
I have not bothered to track down all of the differences in the versions but they are not significant. I do not know why replaced two of the 741s with 301As; I found no engineering reason.
Also the values on my board don't seem to match. A whole host of 4.7uF caps on the schematic are 10uF's on the board. (C34, C38, C138, C20, C120, etc)
An aluminum electrolytic capacitors replacing a solid solid tantalum capacitor needs 2 to 4 times more capacitance for an equivalent ESR especially at higher frequencies.
Except for the big input capacitors and small output capacitors, none of the capacitors will cause failure unless they are shorted which is unlikely with aluminum electrolytic capacitors. I would start checking voltages before replacing them except for the output capacitors.
For what it is worth, the PS503A is my favorite power supply; the floating dual tracking ratiometric output is incredibly useful and I like the coarse and fine voltage controls.
