radioguy123,
So there should be a +0.6v positive voltage on the negative terminal of C17 ?
Circuit analysis reveals this to be true. If this tiny reverse voltage is a concern, disconnect C17.
And this is with the Q9 base still disconnected ? right ?
Attempting to diagnose this non-oscillating condition with Q9 base connected is a bit problematic. RT5, RT4, T29 and R25 provide forward bias to Q9 base-emitter junction. At the same time, Q9 collector-emitter junction begins to conduct, lowering the voltage at RT4/R29 junction. In the non-oscillating condition, where feedback is not present, Q9 base forward bias and Q9 collector voltage settle to a point of static equilibrium where collector voltage limits base forward bias.
How is one to get around this obstacle and better evaluate components in the feedback path?
The objective of this seemingly unconventional test is to check the complete series circuit of RT5, RT4, R29, R25, CR11, VR1, CR10 and T3 secondary pin 4 to 3. If Q9 base is not disconnected, the base-emitter junction acts as a DC bypass around CR11, VR1, CR10 and T3 secondary pins 4 to 3. Again, circuit analysis shows Q9 base must be disconnected, as a prerequisite for this test. The voltages measured can confirm these components to be okay, or provide valuable clues that help pinpoint a fault.
Now for another less than obvious potential cause of failure to oscillate. A shorted rectifier or bypass capacitor on one of the T3 secondaries could reduce feedback amplitude to the point where the circuit cannot oscillate.
For the record, it would be advantageous to know what resistances RT5 and RT4 exhibit at room temperature.
Hope this insight and detail helps understanding,
RF+ Tech
