Hi, here is couple pictures how I did replace burned SSW124 SPDT switch to newer HMC270 switch. "ALC failed" error seems to be quite famous error on old SMIQ and finally my SMIQ did same thing. It didn't take long to find that last SSW124 before output stage was bad (signal from down mixed side was gone). Bigger problem was to find new one. After studying what can be found from Evilbay, I did order HMC270.
Flipping HMC270 over, RF pins match nicely to original layout, and it's much easier to solder to PCB using little copper strip (don't try this without microscope
). Probably original switching voltage levels are little too high for SSW124? but HMC270 can't handle them at all. Control voltages can be lowered easily, just adding paraller resistors to R1150 and R1151. Using 1,8k did give -4,22 V and 2,2k -4,68 V. Using 2,2k/-4,68 V gives over 80 dB attenuation measured from RF output.
OH2LIY
