That's the high voltage flyback board to drive the CRT, it's all one module attached to the CRT - you slide it out as a whole unit. You're looking for the power supply, in your picture it's in the upper left. It will have one or two very large filter capacitors on the input, can't miss it. It is held on with one screw and multiple clips.
