Author Topic: Tektronix tds 460A PSU  (Read 3366 times)
Offline vectra_1098Topic starter
« on: April 10, 2019, 10:39:19 am »
Hi ,
I have another Tektronix Scope a TDS 460A with a failed power supply.
Does anybody have any schematics/pcb layouts for this PSU ??
Thanks in advance...
Offline pbarton
Offline Dacke
Re: Tektronix tds 460A PSU
« Reply #2 on: April 11, 2019, 12:05:00 am »
There isn't really schematics available for the TDS *** scopes as far as I know.   When I rebuilt my TDS 420's power supply I used the schematic for a Lecroy 9354A power supply,  it is about 90% the same power supply,  you just have to be aware of the differences.  I'm not sure if the TDS 460 has a similar supply to the 420,  but a link is here:  http://bee.mif.pg.gda.pl/ciasteczkowypotwor/LeCroy/LeCroy_9354A-M-L-TM_Service_Manual_Complete.pdf  -  pages 8-195 and 8-196.
Offline shakalnokturn
« Reply #3 on: April 11, 2019, 11:40:49 am »
Is it the PS-1690 model you have?
« Reply #4 on: April 11, 2019, 05:10:46 pm »
The PSU has a TEK number on the top silk TEK 119-3939-02
I tried to send a jpeg photo but the site failed to send it
Thanks
Offline z80tw
  • Country: tw
« Reply #5 on: April 11, 2019, 05:18:28 pm »
Just fixed my TDS420A yesterday,couldn't power on.the LVPS failed on Line voltage 110V but worked on 220V,
I took out the power supply board and replaced the C10(22uf/50V).it works now.
The following users thanked this post: vectra_1098
« Reply #6 on: April 11, 2019, 05:54:55 pm »
The photo you just sent, I am pretty sure its the same PSU as mine.
I do have problems though my GREEN Module is damaged and I have removed it from the PSU,
I do recall that there is some  schematics for them ?
 Somebody actually removed the green coating to reveal the circuit ?
Thanks
Offline ctbully
« Reply #7 on: April 11, 2019, 08:45:29 pm »
You can find the service manual here https://elektrotanya.com   :)
« Reply #8 on: April 11, 2019, 10:13:55 pm »
Thanks
Offline maxxim
  • Country: at
« Reply #9 on: January 11, 2020, 06:15:26 pm »
Hi, what is the value of the tantalum capacitor on the underside power supply pcb (hybrid pin 13-19).
Thanks
