Author Topic: Tektronix TDS 754D machine gunning  (Read 885 times)
Offline okwTopic starter
  • Country: no
« on: September 05, 2023, 02:36:17 pm »
Hi! I just acquired a Tektronix TDS 754D with a known faulty display (CRT). They tech salvage company I bought it from said it worked on external VGA. They probably just quickly tested it with a VGA and turned it off again.
I powered it to warm it up at little while I was getting my external screen. Suddenly (3-4 minutes) I heard sparking machine gun sounds. Not quite that loud but still, like some piece of paper was caught in the fan, more more high pitched. I quickly turned it off. By then I felt the smell. Something was definitely happening electrically, like arcing or something. I opened it, found no brown spots, no bursted caps, etc.
It's not too dirty, but some build up here and there with that fine gray dust powder, and some bigger bunnies here and there.
Any ideas?
Done a lot of live stuff, but I've never worked on CRTs, so I'm a bit worried.
I'd be happy to disconnect and use external screen. Or remove the CRT all together, unless they are easy to fix?
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Re: Tektronix TDS 754D machine gunning
« Reply #1 on: September 05, 2023, 03:38:57 pm »
Disconnect the ribbon cable from the top PCB on the CRT side of the unit just in front of the fan above the disk drive.
This will completely isolate power and signals to the CRT board and CRT (but not affect the VGA output).
If you got a bad CRT, it can arc internally. I have a TDS600-something in my collection that was dropped by a previous owner, cracking the neck of the CRT from the shock, and it made similar zappy noises. Luckily I had a spare CRT, so the scope is all working happily again.
  • Country: no
« Reply #2 on: September 05, 2023, 04:47:32 pm »
Thanks. Would it also be possible to disconnect the high voltage circuit too? Or is part of this also powering VGA?
  • Country: jp
« Reply #3 on: September 06, 2023, 05:52:49 am »
Disconnecting the connector I described will totally isolate power to the CRT and CRT PCB, including all HV circuitry.
Offline Jwalling
  • This is work?
« Reply #4 on: September 06, 2023, 07:51:10 am »
My money is on the flyback transformer. It's arcing to the sheet metal that the CPU board mounts on. I've seen this many times.
Jay
System error. Strike any user to continue.
  • Country: no
« Reply #5 on: September 07, 2023, 05:49:08 pm »
Which ones would that be? I'll probably see it when I plug it in :p
  • Country: jp
« Reply #6 on: September 08, 2023, 06:44:17 am »
That's your main PSU board.
The CRT board is to the left, the flyback transformer is the largeish black thing to the rear of the CRT board.
