Author Topic: Compatible CRT for Tektronix 2225  (Read 618 times)
Offline giosifTopic starter
« on: November 09, 2024, 04:27:27 pm »
I have a Tektronix 2225 with a broken CRT and, apart from getting the exact replacement for it (already asked in the Buy/Sell/Wanted section), I was wondering what other scope model might be using a compatible tube.
I have a 2235 scope and I was initially thinking of using the CRT in it, but then realized that tube has the connections to the deflection plates on its side, whereas the tube in the 2225 has all its connections on the neck connector at the back.
Does anyone know of any other scope with a CRT like the one in the 2225?
Online bdunham7
Re: Compatible CRT for Tektronix 2225
« Reply #1 on: November 09, 2024, 05:08:59 pm »
AFAIK, the CRT for the 2225 is unique to that scope and its relatively rare derivatives (see the Tekwiki page).  The p/n is 154-0907-00 and I believe QService shows one available.  IDK if a more common CRT might be made to work by rewiring the deflection grid circuits.
Is your 2235 functional?  If not, perhaps it would be better to repair that scope?
« Last Edit: November 09, 2024, 05:10:39 pm by bdunham7 »
« Reply #2 on: November 09, 2024, 06:04:32 pm »
Yeah, I was afraid that may be the case.
Based on search results, it appears the Tektronix 2211 is another scope model using the same CRT.
I did see the tube on QService's site, but the cost would be over EUR 130.  :)
This is what I am looking for.
It isn't working, but I do not recall what specifically is wrong with it.
Might be broken CRT as well.  :-//
Offline Jeff eelcr
« Reply #3 on: November 10, 2024, 12:24:43 am »
2225 should be a common scope in europe, how much is a replacement or parts scope compared to the tube?
Jeff
« Reply #4 on: November 10, 2024, 09:36:52 am »
I couldn't find any for parts 2225 up for sale (or recently sold) on the bay, but working ones seem to go for over GBP 100.
Offline factory
« Reply #5 on: November 10, 2024, 10:39:33 am »
You need more patience, it can take a long time to find some parts, or a reasonably priced replacement scope of the same type. Too many lazy/stupid sellers using the flawed ePay AI pricing suggestions, why else would a 50MHz scope be advertised at such crazy prices?
[/quote]
Why would the CRT be broken on 2 scopes? in my experience it's rare to find a broken CRT, lack of anything displayed is usually a fault somewhere else.
« Last Edit: November 10, 2024, 10:45:34 am by factory »
Offline George Edmonds
« Reply #6 on: November 10, 2024, 11:20:24 am »
Hi
The standard problem with ALL Tek 2000 series scopes is power supply electrolytics.
I have several scrap Tek 2000 series scopes, but not a 2225.  If you do try to replace te CRT with a different one please be aware that there are a number of PDA voltages used in the 2000 series.
G Edmonds
« Reply #7 on: November 10, 2024, 11:54:05 am »
I wish the problem with my 2225 was the electrolytics, but I'm 100% certain the CRT is toast (i.e. the glass pillars holding the electron gun and deflection plates have been broken on one of their ends and there are pieces of glass roaming freely inside the tube; otherwise, the tube still has vacuum :) ).
Converting another CRT for use in the 2225 is not something I'd engage in as a "quick project" and I was hoping to take advantage of any prior work done in this direction.
Offline grumpydoc
« Reply #8 on: November 10, 2024, 01:19:23 pm »
If you are interested I have 2x 2235's, I don't have a 2225 (at least not that I spotted on a quick search - I'm sure I had one, but probably sold now).
At least one of the 2235's should be working (or was when I put it away but that was quite a long time ago).
If interested make me an offer, collection best & I'm in the Midlands. Will need at least one weekend to check that it works.
« Reply #9 on: November 10, 2024, 08:41:30 pm »
Much appreciate the offer but, at this stage, my intention is to try restore the 2225.
Thanks again!
Offline grumpydoc
« Reply #10 on: November 10, 2024, 09:15:19 pm »
Thanks again!
No worries, let me know if things change.
In the meantime https://rsgb.org/main/news/rallies/
The following users thanked this post: giosif
« Reply #11 on: November 11, 2024, 07:48:40 am »
Will do.
Thanks for the link!
I was looking for such a list.
