Author Topic: Tektronix TDS3012B Date & Time slip  (Read 1856 times)
Offline GangwayTopic starter
« on: December 19, 2018, 03:31:02 am »
Just asking if anyone knows if this scope has back up battery for date & time. My unit panel mounted, so pain to open up.
Cheers
Re: Tektronix TDS3012B Date & Time slip
« Reply #1 on: December 19, 2018, 04:30:26 am »
Not looked but the info is probably here:
http://w140.com/tek_tds_3000_series_service.pdf
« Reply #2 on: December 19, 2018, 07:14:17 am »
Thanks for link, had already scanned this document, but no info or circuit drawings relating to clock source backup.
Offline Jwalling
  • This is work?
« Reply #3 on: December 19, 2018, 10:26:12 am »
There is a Dallas DS1742W PDIP with an internal battery. Yours is probably dying.
Part is EOL (Dallas/Maxim sucks!)
Jay
System error. Strike any user to continue.
« Reply #4 on: December 19, 2018, 12:04:36 pm »
Thanks JW, that sounds like the issue, 10 year life span. Will have a look in the new year, cheers mate.
« Reply #5 on: December 19, 2018, 12:47:27 pm »
Jw
Just found your previous reports re this bad NLA chip & other excellent  articles about modifying it for external battery cell. Had no idea this chip was a known dud. So when the battery goes flat, I guess the cal data goes.
Offline voltsandjolts
« Reply #6 on: December 19, 2018, 12:54:12 pm »
No, cal data will be fine.
I have replaced a 3034B BBRAM with a blank device and was all fine - BBRAM just seems to store instrument setup (timebase etc) and date time.
The following users thanked this post: Gangway
Offline Jwalling
  • This is work?
« Reply #7 on: December 20, 2018, 10:39:07 am »
Jw
You won't lose the factory calibration, but you will lose the SPC constants. You'd have to run the SPC  before using the scope.
Jay
Offline TheNewLab
« Reply #8 on: December 22, 2018, 02:33:10 am »
here is a YouTube. explains, and does with clever temp solder of a battery so the CMOS never loses the settings
However, if date/time does not keep..and the battery is dead..that means calibration..Others on this forum would know more about the latter
