I'm sorry if this topic has been covered previously, I did a search and didn't find anything. I could have missed it, kindly point me at a link and I'll go away.
My trusty old TDS3054B is misbehaving. I've owned this since it was new (bargain auction- new in box at a startup). I have never had a minute's trouble, it really isn't that special anymore though with limited memory, a small screen and 9 bit ADC but 5 Ghz and 500 Mhz still aren't bad.
The problem: All will be working fine for 10 minutes to 3 hours and it will just power cycle and reboot. It comes back where it was and will do it again some random time later forever. It seems that the longer its on, the less likely this is to happen. Once I got a warning that the input terminators were getting warm (non sense, no signals applied), I've seen this in Youtube videos when people operate them outside the case without airflow but mine is fully buttoned up, the fan is running, etc. I cleaned out all the dust with compressed air, etc and verified the fan is running and exhausting air. I ran a continuous self test and it doesn't show any errors (I'm going to do this overnight). Is this a known problem?. It sure smells like a power supply or temp related overheating issue related to big caps- just guessing. I haven't opened it yet, want to gather some knowledge and docs. Its usable as is and I don't want to really break it, "the enemy of good enough is better." Also, firmware is up to date, AC supply is coming in clean with no glitches. Does this with no signals applied and applying signals and other setting don't seem to affect.
Any help appreciated.
