For a few years now i have used my Tek TDS3054B as my reliable old faithful scope on my work bench but I was always aware that for such a small scope with it plugged in but "off", i suppose in a Standby mode, the Top of the scope always got remarkably hot.
Until recently i just kept it off for as long as possible, but knew i was on borrowed time with it. Recently i started getting 80+MHZ ringing every 3uS or so. Reading a few threads online it led me to believe that the PSU was on its last legs. Now not being a fan of Noisy (although admittedly more efficient) Switching PSU's, I decided after looking around to just replace the module. For the sake of time/convenience. However having now done that i dont know if it was quite worth it. But here's a little story i suppose.
The Tek Service manual states it is a NAN40-7615 PSU. This is now Obsolete, but the manufacturer states that an LPS44 model is a replacement, in stock at RS UK, so i ordered one up and turned up in no time.
I stripped the scope down and found the following snags, which anyone else who might chose to do this repair should be aware of;
1) The Line Input connector Polarity is inversed.
2) The Line input connector is moved closer to one side of the PCB, this makes fitting it difficult as the Line solder almost touches chassis.
3) The Earth connection for the PSU is moved to the other long edge of the board, the metalwork it is screwed to, does not have a direct connection to Mains Chassis/Earth, so is now floating.
4) The 15V Output connector has moved a few mm, which makes fitting the output connector trickier but not impossible.
5) Additional Heatsinking on the PSU board, means the Fan cable has to be routed slightly differently (no biggie) & Option tray foulled.
In the end, i did get it to fit and works fine, however i will break these points up into multiple posts
Fix for issue #1 - The Line connector, can easily be de-pinned and polarity swapped.
