Author Topic: Tektronix TDS500-C/D Mono to TDS700-C/D Color Conversion  (Read 562 times)
Offline strickTopic starter
« on: November 08, 2023, 06:57:45 pm »
I'm attempting to convert a couple of TDS540C CPU boards to color and use the standard Tektronix Nucolor display (the CRT with shutter and HV module).  This thread https://www.eevblog.com/forum/repair/conversion-tektronix-tds500-to-tds700-color-oscilloscope/ discusses adding the missing ram and changing a resistor, but assumes that one will use a 3rd party lcd display using the external VGA port.
However, in one section, a user (PerpetualWalnut) did this same conversion (e.g. 540 to full 754), but only gives a few clues to some of the parts required.  He shows the top and bottom of the board (enclosures 1 & 2), but fails to mention the resistor values on the bottom.  Enclosure 3 shows the bottom of a TDS784D board that I bought, but someone had removed the two resistors in the bottom left (circled).  The other resistors that are replaced (shown in enclosures 2 and 3) are all 1002 (10K).
Could someone please take a look at their TDS754/784 C or D CPU board and inform let us know the values?
thanks,
Strick
Re: Tektronix TDS500-C/D Mono to TDS700-C/D Color Conversion
« Reply #1 on: November 08, 2023, 06:59:09 pm »
The board only let me post one picture.  here is the second.
« Reply #2 on: November 08, 2023, 06:59:51 pm »
and the Third, showing the two resistors removed...
Offline Tantratron
  • Radio DSP Plasma
    • Tantratron
« Reply #3 on: November 12, 2023, 11:39:18 am »
Hi Strick, this is Albert from France
Attached close view of one my TDS700D repaired, let me know if you need more info.
First resistor 5230 and second resistor 75R0
« Last Edit: November 12, 2023, 11:44:58 am by Tantratron »
« Reply #4 on: November 12, 2023, 02:29:21 pm »
Ah,
thank you Albert!
Strick
