Peak detect is an acquisition mode. If you use the scope to look at high frequency signals you'll probably be OK. I used to have a TDS644A but it turned out to be completely useless for general purpose work (look at vsync signal on a relatively slow time base for example) due to lack of peak detect. So out it went.
