I have a Tektronix TDS684A with a very dim color screen. It started out where I could see nothing. And of course it had the curdled optical coupling gel between the crt and the shutter. So I cleaned out the gel and still the image is very dim but is there.
Now I am debating whether I should screw around with the crt controls ?? Adjust the brightness ? I have heard horror stories where messing with
these controls could actually damage the video chips on the main boards ? I don't know.
Of course there are the VERY EXPENSIVE lcd replacement kits. I don't want to put that much money into a very old and questionable oscilloscope.
I guess what I want to know is are there people out there that have replaced the color crt with inexpensive Chinese lcd and controller boards from ebay ?
I realize you would need a lcd that would fit the space. And a 4:3 aspect ration. Also the lcd would have to be able to display the 640x480 video signal available at the back of the scope. Unless you are very good with electronics and can create the circuits that the kits have and take the signal from the video chips. I have been trying to contact some of these chinese vendors and truthfully they really don't know what their selling.
I have found some possible candidates on ebay and will list some links here. But those links probably won't be valid for very long.
https://www.ebay.com/itm/LCD-Screen-7-800x600-A070SN02-work-with-VGA-LCD-Controller-Board-KYV-N2-V2/143460478498https://www.ebay.com/itm/7-CLAA070MA0ACW-TFT-LCD-Screen-HDMI-VGA-Driver-Controller-Board-800-600-Kit-US/114307076772Both of these boards should have a VGA input. Unfortunately the controller boards have keyboards that need a button pressed to turn them on.
So I don't know if once turned on will turn on again with just power on. That could be a problem.
And these boards will of course need a 12vdc source. That 12vdc is hard to come by on these oscilloscopes so a dc to dc converter will be needed.
Once again communicating with the vendors they didn't provide any useful information.
So just reaching out there for some useful information.
thanks
