Author Topic: Tektronix TDS754A Error?  (Read 580 times)
Offline sampler1Topic starter
« on: March 16, 2020, 03:27:03 am »
 I picked up a Tektronix TDS754A and the first thing I did was to run the self tests. All seems quite good but I get this one error message;
error cal meas clipped at min dig ou (0@B0010: -5.119 divs
Would anyone have an idea what this message is? I was told when I bought that the acquisition board should be recapped..
Any ideas at all would be greatly appreciated.
Best regards
Garry
“Electronic devices are powered by white smoke. When smoke goes out, device is dead.”
Offline ArcticGeek
Re: Tektronix TDS754A Error?
« Reply #1 on: March 17, 2020, 12:46:58 am »
I doubt that recapping the Acquisition board will help much.  While it is true that Tek had serious problems with caps leaking on early TDSXXX units like the TDS520A, 544A, 644A, and the like, the newer units didn't really have that many issues.  I assume this is because the quality of the caps improved by the time the newer units came along.
Do you get this error during the self test or during SPC calibration?  The reason I ask is that this error is common when running SPC - this is usually fixed by replacing the relays of the attenuator hybrid.  I haven't seen this during diagnostics, but I suppose it is still possible.
One thing that would be helpful is to attach a console port to the main board when you boot up and when running diags and/or SPC.  This will spew out errors when it encounters them and that is usually a good clue.  At the very list it may help to determine which channel is having issues.
Offline james_s
« Reply #2 on: March 17, 2020, 04:35:03 am »
I would certainly start by taking a close look at the boards, if you see dull corroded solder at any of the SMT electrolytic capacitors then they are leaking. Leaking caps are the most common cause of faults like this, none of the models that use them are immune.
