Hello all, I have a TDS754D with a rather strange issue, and could use any help on diagnosing I can get.
Symptoms:
-Fails acquisition board self test
-Channel 2 is funky, will expand on that
-All other channels work perfectly
Extras:
-Original Dallas NVRAM, still holding on but needs replacing
-Electrolytics are still on the serial board, also needs replaced
-Dim display(seems like a common thing with these)
Channel 2 doesn't respond to inputs, and appears to have lots of glitches in the trace. An acquaintance said that it looks like it's "dropping bits", which makes sense to me but I have no idea on how to diagnose it. What I find odd is that the glitch changes the way it looks seemingly at random at each startup, the images attached are the three different states it goes into.
Any input would be great, thanks!
