Author Topic: telefunken solarize the images 17mb25-3 v1 060309  (Read 1997 times)
Offline albottTopic starter
« on: July 03, 2016, 02:47:16 pm »
i've a problem with a telefunken tv that solarize the images.
In a first step i've changed the ic (CM1671B) on the t-con board (V260B1-XC11) with negative result.
After that, i've seen that with teletext, the problem does not occur. So the problem isn't the t-con board.
The problem occour also with hdmi input (xbox360).
Can anyone help me?
Here, you cand find the service manual of the board (mb25): http://alessiobotticelli.com/manuali/MB25_SERVICE_MANUAL.pdf
Thx in advance
« Last Edit: July 03, 2016, 02:57:36 pm by albott »
