I have an old phone with a removable battery for which had been able to get a replacement copy. The phone's battery life today is much shorter than when new, and the battery must have eben through >1000 charge cycles in its life, I'm trying to work out when I should swap to the spare battery though. The battery is a dumb, or mostly dumb, type with 3 pins (+V, Gnd and one which I think is temperature sensing), the phone itself contains all the charging controlling chips. Are there any multimeter tests I could make of the battery which would determine when it is time to swap the old one for new? Or should I just keep using it until it won't charge at all (I've seen that happen to a laptop battery many years ago). Do phone batteries ever spontaneously ignite just from age *there's no swelling or mechanical damage or anything like that involved in this matter), would it therefore be wise to swap over to the new battery soon and dispose of the old (but semi-working) one ASAP? The new one appears genuine and seems to take charge fine turing some test runs, but I can't be 100% sure about it. I do not have any kind of specialised internal resistance meter or milliohm-meter, except to the extent that such could be formed by building up other circuits to feed signals/voltages to a mutlimeter or oscilloscope.
Thanks
