Hi all,
I have a new Tenma 72-2645 power supply (rebranded Korad KA3305P) where, as soon as I power it up, the fan starts.
According to
this Korad 3305P teardown, that shouldn't happen: it's supposed to be silent until it actually starts to deliver current.
But worse, although it's running, it sounds like it's "growling" - it's not a smoothly humming fan. I opened it up and the fan is definitely turning: it's not "twitching" in place like I've seen some fans do. So I
recorded the sound.
I doubt it's the fan itself, since that spins fine. It's more likely to be the fan controller or temperature sensor: it kind of sounds like the fan is being turned on and off many times per second.
But any suggestions are welcome!
[Edit]
In the following picture from the above post,
at the top left behind the large cap you can just see a trimpot (trimcap?). I was wondering if this could possibly be an adjustment to the temperature sensitivity? It's the only adjuster that I can see on the whole PCB.
