Hi ,
I bought this tool from E-bay, built primitively, hoping that it can be easily repaired, I see that inside the PCB are from UT805, it means that Tenma 72-1023 is a clone of UT805. What is the problem: at start-up everything is fine, no error occurs but if I switch it to any measuring range it crashes and does not recover until after restart, I suspect that something is blocking the communication bus… I replaced the measuring circuit ES51986A but in vain the defect persists, I checked the voltages and supply capacitors with the ESR-meter, they are ok, a scheme would be welcome or a troubleshooting idea.
Thank you .
Costas
