Hello...
I have this Tenma 72-7720 equipment. I know it doesn't worth the trouble, but I would like to know what could possibly be the origin for the malfunction I'm about to describe!
Originally this multmeter came with a fuse of 500mA for the uA/mA current circuit! At some point it broke and I switched to a 200mA fuse! But it always worked ok.
And as I'm a student, there was some time now that I haven't used the equipment. Yesterday I needed it and I noticed that it was measuring current with a 10x scale factor error. I mean, if I have 4.8mA, the multmeter measures 0.48mA.
I checked the fuse again and it was completely burned. Looks like there are small pieces of burnt material inside the fuse. It's not only the thin wire that is broke. The fuse is completely black.
So I wonder if is there anything that might have happened in the past that the fuse could not protect the multmeter from!
Is there any common/known reason for this to happen?
