Author Topic: Cleaning up after bad tantalum  (Read 783 times)
Offline Gip-Gip
« on: May 14, 2017, 03:36:05 pm »
A tantalum went bad in a HV supply and seems to have left some corrosion. Would anyone know what that could be?
I've tested everything else and it all seems good
Offline David Hess
  • DavidH
Re: Cleaning up after bad tantalum
« Reply #1 on: May 14, 2017, 09:12:06 pm »
What kind of tantalum?  We tantalums use sulfuric acid which is an obvious problem that needs to be neutralized.  Solid tantalums just leave a dry inert residue which can be cleaned with anything which will remove it.
