Author Topic: Test gear for amateur radio tune up, repair and fettling?  (Read 5586 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: February 29, 2012, 09:35:10 pm »
Being into automotive engine management system electronics I have some
basic test gear, but I am a bit of a magpie for buying more stuff :)
In order to buy the *right* sort of stuff for my newly rekindled
interest in amateur radio may I ask what people recommend in the way
of test gear to set up used, repair broken, and basically fiddle with
"unknown" newly acquired used ham radio stuff?
I currently have a Phillips/ Fluke 2 channel 100 MHz Combi Scope (on
the fly switchable analogue to digital), a Tektronix 7633 mainframe
with an assortment of plugin modules, a decent 150 MHz USB scope with
two channels, a 2 MHz combined signal generator / frequency counter,
that's very basic, but works OK. I have a small Peak semiconductor
tester, and the same make ESR capacitor tester. I also have a basic
cheapo hand held DMM, and a couple of 4 1/2 digit bench multimeters. For
soldering I have a Weller thermostatically controlled 20 Watt soldering
station, and a now broken Weller de-soldering station. The thermistor
in the de-soldering iron is broken, and spares are no longer
available. the vac pump in the base station works fine, which is a
shame.  I  need to replace this ASAP, but bear in mind I am in the UK,
so don't get the same range of stuff like Hakko you seem to get in the
USA.
I am thinking in terms of a better signal generator, and a separate
standalone frequency counter. What sort of range do these need to be
truly useful? I might want to have a go at building some 10GHz stuff,
or at least having a play on that band. I guess test gear for
microwave stuff will be VERY costly, how do people manage there?
I think I could do with an RF probe, and a high voltage probe for
valve stuff. Again, what sort of range do I need? 500 MHz RF probe OK?
In some of my Yaesu manuals they only speak of using a VVM for RF work,
but this is 1980's stuff, is there any reason not to use a fairly modern DMM instead?
What other gear do people find useful? At the least I would like to be
able to follow the tune up instructions for older gear myself, in
house.  I  would  also  like  to  see if a receiver is "deaf" and if a
transmitter is free from terrible harmonics. I guess I am getting into
expensive spectrum analyzers there though?
Thanks for reading.
Best regards,
                 Chris Wilson.
Offline JonnyBoats
    • BitsConnect
Re: Test gear for amateur radio tune up, repair and fettling?
« Reply #1 on: March 02, 2012, 04:46:46 am »
Whoa Chris,
This is amateur radio with a strong tradition of make do, recycling old bits and making one's own gear. What you already have will do 99% of what you need to do, why not just jump in and have fun?
Heck, I may be old, but I remember tuning up a transmitter into a light-bulb as a dummy load. Back then nobody had a digital meter of any kind and certainly not a high precision digital frequency meter. People were still able to communicate around the world and make lots of contacts.
If as you start building specialized projects you find you really need a piece of test gear, then buy it then, not now.
WA1KLI
Offline sonicj
  • updata successed!
« Reply #2 on: March 02, 2012, 12:29:33 pm »
Bird 43
Offline vk6zgo
« Reply #3 on: March 02, 2012, 03:28:18 pm »
The 'scopes are a good start,especially the 7633,which has a useful feature (at least my 7613 does),in that you can get access to the output of the vertical plug in,& use it as  a variable gain buffer amp for such things as Frequency Counters,speaking of which,the cheap Chinese ones seem OK---I've got one.
If you could find a 7L12 Spec An plug in for the 7633,you would be set!The 7L12 isn't all that marvellous,but it will do the job!
A Test Load (Dummy Load) is almost essential.especially if you can get one which gives you an attenuated sample of your RF signal.
You can build a lot of stuff----  An RF probe for your DMM is an easy start!Another possible project is a Dip Oscillator.
Your existing Signal (function?) Generator is fairly limiting,but most really good Signal Generators are either very expensive,or very big & old! ;D
HP stuff is very good,as is Rhode & Schwarz & Boonton,but I would suggest you stick to the old Brit stuff.
Marconi made some very good Generators,as well as some not so good,plus there were many other Test Equipment manufacturers in the UK back in the day.
Finally,I would suggest you sign up for QRZ.com (I don't think Dave minds us promoting other forums here!).
They are a nice lot,if a bit crazy,but you've got used to that on this forum! ;D
73,VK6ZGO
Offline G7PSK
  • It is hot until proved not.
« Reply #4 on: March 02, 2012, 03:45:14 pm »
About the only thing that is a mandatory requirement for amateur radio is a means of checking your output frequency, and an absorption wave-meter will do for that.
« Reply #5 on: March 02, 2012, 05:50:37 pm »
I have come upon an issue already that I don't believe I have the gear to resolve myself, at home. My newly acquired Yaesu FT-902DM transceiver seems to be displaying a different receive frequency to that which it is actually listening on. Now, I *MAY* be able to check it on a known HF frequency transmission, if such things exist, but can I re trim it to read correctly without a decent calibrated signal generator? Similarly, can I accurately check the displayed transmission frequency matches that which it is displaying? These two checks seem pretty essential with used gear, i would like to be able to at least do these checks with accuracy. I am off to Google building an RF probe, as the old HP one I am watching on Ebay is up to 50 UK pounds already. Thanks for the replies so far.
Best regards,
                 Chris Wilson.
Offline G7PSK
« Reply #6 on: March 02, 2012, 06:12:35 pm »
It is a transceiver, is the frequency displayed the transmit frequency, which is different from the receive when working repeaters.
It could also be that the clarifier is in use it shifts the receive up 2.5KHZ.
If you don't have the manual its here:   FT-101ZD-901-902 - Fox Tango Yaesu Manuals
www.foxtango.kc9foz.com/FT101ZD...902/FT-101ZD-901-902.htm
« Last Edit: March 02, 2012, 06:36:14 pm by G7PSK »
