FloobyDust, are you speaking of this one?
If so, this is R316 , a 3 watt 470 Ohm resistor in the power supply circuit.
This is the resistor that indicated to me a problem. It gets really hot!
I disconnected it.
It is located just before the HV Oscillator board.
R316 is running hot perhaps because the oscillator is probably working like crazy to lower the voltage at TP 402 from -675V to -1500V. Q402 and Q403 are probably running saturated.
This indicates that something is either pulling TP 402 up, or preventing the oscillator to provide the adequate voltage.
I will also post an ad in Raleigh's Craigslist in hopes of finding someone able to test the CRT
As
floobydust hinted, there are no CRT testers out there. The best way to test a CRT is using the scope itself. However, if you want to test it outside the scope, you can perform some simple tests yourself.
The most important one is the filament continuity test. If your CRT is the same as used in the LBO-301, you should see continuity between pins 1 and 14. Apart from those pins no other pin must present any continuity with any other pin. So, start with pin 1 and test it for continuity with all other pins from 2 to 13. Then take pins 2 and all others from 3 to 13, and so on.
Then, you can perform the "emissions" test. Just connect pins 5, 6, 7, 11, 12, 13 together, and 1, 2, 3 also together and apply 1500V between them like in the picture below. Leave pin 4 disconnected. You should see a bright spot with a diameter of 1cm or so on the screen. But I guess that won't be necessary, once you solve the issue with the HV supply.
I want to quit my day job and do this stuff from now on
Oh, my! You need to talk to
these people. They may help you with your job-quitting ideation. Maybe not.
