Alright, here's a list of what parts I have or what's on order from Digi-Key:
...and FloobyDust, I couldn't find any diodes matching your spec's or that part number yet, so if you have a supplier near you, please send me their phone number or link, and I'll keep checking though. Thanks!
For the 3Kv 1000pf capacitors, C406, C407, C420, and C408 on the main board, I ordered Kemet's GoldMax 5% 125C X7R's (C330C102JHR5HA). They seem to be built pretty stout (I'll attach a picture of their construction, kind'a neat).
For the 3Kv 470pf capacitors, C410 and C420 on the main board, I ordered TDK's CK45 Series 10% 105C ceramics (CK45-B3FD471KYGNA). They're not potted and easy to get to.
For the 22K 1/2 watt resistors R427 and R428, I have a choice of several different ones on-hand:
Vishay 22K 5% 155C 100ppm Metal film 1/2 watt
Dale 22K 2% 175C 200ppm Metal film 1/2 watt
Stackpole 22K 5% 155C 500ppm Carbon film 1/2 watt
TE Connectivity 22K 1% 155C 100ppm Metal film but in a 1 watt size.
For the 470 Ohm 3 watt resistor R316, I ordered a Panasonic 5% 235C Metal oxide film (ERG-3SJ471).
And FloobyDust, the 47 Ohm 1/2 watt resistors R306 and R312, I have Vishay 47 Ohm 2% 150 C 100ppm Metal film or Stackpole 47 Ohm 5% 400ppm Carbon film. Probably doesn't need to be anything special.
I totally agree, I don't want to use any of these old parts. So the delay will be the diodes.
I measured the volume of the potting tray and it is 1.6 cubic inches (26.22ml), so I'll get searching for that Silicone potting stuff (MG Chemicals). It comes in a clear formula by some, so it would be cool to see the components floating in it
I did use my Fluke 8024B DMM to test those original diodes and the user's manual states it uses 3.5 volts or less for the diode test.
And just one other thing that I noticed, power transistor Q401 on the HV Oscillator board, it's supposed to be an NPN 2SC1059, but what's installed is a 2SC1168 X. Who knows, but I do have a new Motorola gold-pin JAN2N3739. Do these transistors happen to interchange?
Fun stuff!
...now the weeds need pulled, the lawn needs mowed, the garage...
Happy Fourth of July!
