Thank you
BSFeeChannel.
C408 and C418 are new and both were tested before the first rectifier module was installed, and again, after the second rectifier module was installed (I desoldered the caps and tested them for leakage at 600v out of circuit on the Z-meter).
I will remove the caps and test them again, or even replace them with another pair of new 470pf and 1000pf caps.
When you mentioned at first to turn the VR401 down to 14 volts at the base of Q406, are you saying that -1500 should have been read at TP402 (14v @ Q406= TP402 -1500)?
It wasn't until I turned VR401 down to 10.6 volts on the base of Q406 before TP402 reached -1500 VDC.
I also turned VR401 down even further and exceeded -1650 VDC on TP402.
When I stop turning VR401 and remove my plastic screwdriver, the voltage on TP402 remains rock steady.
FloobyDust:
When TP402 is at -1510 VDC, Pin #2 on the CRT measures -1190 VDC and Pin #3 measures -1500 VDC.
The variable resistor for intensity (VR403) works great.
The "intensity" pot on the front panel (J403) works great.
And BTW, if the neons are in series on the -1500v rail and remain lit, what are they sensing?
...and I think she's smiling
