If you want a quick and dirty method, set the PSU to 40V and 15mA current limit and connect it to a dead cap with DMM showing cap voltage and maybe another DMM showing current into the cap so you can fine tune the current limit if needed.
Use a stopwatch to figure out how long it's taking for the voltage to rise by 1 volt.
For 15mA and a 15000uF cap it should be 1v per second
0.015 A / 0.015000 F = 1 volt per second
This method doesn't work so well for smaller caps because you need such a low current limit and it tends to drift.
But for 15000uf a 15mA limit should be doable on most psus.
Be careful with the charged cap you end up with at the end
15000uF at 45V will give a decent bang
