I just bought a Hantek 6022BE oscilloscope.
After pluggin the Hantek in, Windows 10 doesn't start the driver installation as it should when a new device is detected.
Linux 16.06 doesn't change the usb device list when compared with lsusb.
Win 7 detects that something is plugged in but if you install the driver, it ends to not detected unknown device.
All ports and cables are fully functional and tested.
I opened the oscilloscope and detected soldering of the ADC-chip under the sink has the following:
counting from the dot near label U8, some pins are soldered together, I can't say if that's a mistake or not (not too professional looking...):
- 3+ 4
- 5+6+7
- 9+10
Please see the attached pictures. (The black fabric tape on top of the sink is put to control the light reflections )
My board version is 1.00.2 , board says 012-05573BH (a lot number ? ), serial 61040771.
The drivers are the newest downloaded on 01/20/2017, I also tried the driver included in the package.
Sending this back to celebrating China costs 46 € (!!!) from Finland (and takes some time...), so I'd prefer to report well enough to avoid the shipping and waiting.
Can anyone help with :
the pins - tell some electrical test routines originated from the manufacturer
- how to dump something out of the equipment
https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-dso/ The power consumption is measured 350 mA from USB, Cypress in Hantek is programmed to say 100 mA ...
