Author Topic: Thandar TM351 - First repair  (Read 703 times)
Offline Hammie217Topic starter
« on: February 26, 2020, 04:14:42 pm »
Hi all,
This is my first repair attempt, I picked up a thandar TM351 and TM355 and some Fluke multimeter for £30 for an attempt at repairs.
The TM351 is in fairly good nick except for a small battery leak that seems to have damaged the screws more than anything else. The meter seems to work well on some modes but others not so much (Table of buggery below (X shows not correct)). Some of the higher ranges are taking a while to settle but I'm assuming that's normal.
DC:
0.2220200200020000
Ohms
Amps
Voltsxxxx
AC:
0.2220200200020000
Ohms
Amps(all reading the same)xxxxxx
Volts(all reading the same)xxxxxx
There are datasheets online here:(https://www.kevinchant.com/uploads/7/1/0/8/7108231/thandar_tm351-workshop-manual.pdf) but any help as to what to look for would be greatly appreciated  :-/O
Thanks,
Hamish
Offline tekguy
Re: Thandar TM351 - First repair
« Reply #1 on: September 25, 2022, 10:53:13 pm »
i have the same issue,no answers?.
