Tim, you used 10 minutes as your charge time. If you repeated the experiment with a pulse generator, would it not decrease? Also, wouldn't the discharge time also decrease?
On a different note, what is the inductance of a superconducting magnet? There can't be a voltage present except during charging and discharging.
If I repeated the experiment, I'd still have the same minimum figure. A pulse generator would only give a weaker minimum.
Superconducting magnets are usually in the henries range, AFAIK. You can't measure it just sitting there, of course -- H and F are dynamical units (ohm-seconds and seconds per ohm, respectively).
If you know how much energy was put into it, and at what current, you can calculate the inductance, charge time (for a given input power or supply voltage) and whatever. To a certain extent, you can get around this by probing instead (say with a magnetic field probe, measurements of the geometry, and measurement of the enclosed current with a non-contact ammeter).
Note that my above measurement looked like it was "just sitting there", but no measurement is perfectly accurate, and following the assumption that it was, in fact, changing imperceptibly within that error range, gives an estimate for the minimum capacitance. It could always be more, indeed it could be infinite as we expect a short to be (i.e., not a capacitance at all, in any meaningful sense, just a resistance).
So, this is also a lesson about the ways we can interpret the error bars of our instruments. Are the LSBs changing? Are they noise? How can we tell? If so, what estimate can we give for a min or max condition, that would still be consistent with our measurement?
Incidentally, even if the voltage were observed to be zero, that doesn't cause an error -- we interpret division by zero as a single point at infinity. The reals are a continuous ring, connected at \$\pm \infty\$. When we take 1/x, we are in effect mapping that region (i.e., from -infty to +infty) to the region around 0. This seems even more strange on the complex domain, where the perimeter at infinity (in all directions) is a single connected point, by the same mapping function.
Less abstractly -- suppose we have a resistor of nearly-infinite value, in parallel with a resistor of nearly-negative-infinite value. What's the parallel equivalent? An open circuit is still a frickin' open circuit!
