Author Topic: The PC motherboard POSTs every other time  (Read 2015 times)
Offline FileNotFound__Topic starter
  • Country: hr
« on: June 29, 2022, 05:07:57 pm »
The PC works, every other time.
When I try to start it, the fans and the harddrive spins up, but there is no disk activity or anything.
When I try to restart it, it boots up just fine.
I tried switching the power supply and the ram but it didn't help.
I concluded the issue is the motherboard, because in the system there is no external graphics card or anything else that could cause no POST.
I am hoping, since the board is half working if the issue could be fixed, if it could be a capacitor or something I could easily replace.
« Last Edit: June 29, 2022, 05:11:02 pm by FileNotFound__ »
Offline golden_labels
Re: The PC motherboard POSTs every other time
« Reply #1 on: June 29, 2022, 08:49:21 pm »
Firmware (BIOS in older motherboards) falling back to default/safe settings after a failed boot, allowing one start to correct invalid configuration and then using the incorrect options again?
People imagine AI as T1000. What we got so far is glorified T9.
  • Country: hr
« Reply #2 on: June 29, 2022, 09:53:17 pm »
I am not getting any messages or anything about the cmos being reset, time and settings are beeing saved.
« Reply #3 on: June 29, 2022, 10:11:15 pm »
During POST or in setup? I never seen anything like that being reported during POST either. It “just happens”: the system doesn’t boot, restarts, “safe” settings are used. I could only tell because there is a warning about that in the configuration.
But if it’s not firmware trying to restart into safe configuration, I don’t have other ideas to offer. Other than asking, if there actually is a pattern: how many times did you try and did you observe exactly that behavior every time, with no single exception?
Offline macboy
« Reply #4 on: June 29, 2022, 10:30:19 pm »
I agree with that it may be bad BIOS/EFI settings causing the failure and a fail-safe default that works on the second try. Get into the BIOS settings and load defaults, set important things (date/time, SATA mode, boot device) then save, reboot and see what happens.
  • Country: hr
« Reply #5 on: June 29, 2022, 10:37:21 pm »
When the sytem detects an issue, it usually trows up an error like the one in the picture (not the same system) and asks you to reconfigure it.
"if there actually is a pattern: how many times did you try and did you observe exactly that behavior every time, with no single exception?" Well, it happens every time I try to start the system, it turns on, and does nothing, reset button does nothing, holding the power button turns it off, and then it starts just fine on the next attempt. This isn't a power cycle like ram training or failsafe, it just turns on and does nothing untill iI force it to turn off. There were some exeptions but they are rare. Exiting the bios also breaks it.
  • Country: hr
« Reply #6 on: June 29, 2022, 10:41:11 pm »
Loading optimised defaults did not help
I just read that my CPU does not have integrated graphics, instead the motherboard's chipsets is used as the graphics card. Could that be the source of my problems?
« Last Edit: June 29, 2022, 11:13:06 pm by FileNotFound__ »
Offline abdulbadii
« Reply #7 on: June 30, 2022, 12:17:21 am »
update latest BIOS yet, ensured good coin cell battery V?
Offline Whales
    • Halestrom
« Reply #8 on: June 30, 2022, 03:13:29 am »
Modern motherboards perform ram training in the first moments of startup.  Sometimes they save good configs, sometimes not.  Perhaps try reseating the ram, trying only a single stick, trying it in a different slot or trying different RAM?
Offline lugaw
  • Country: jp
« Reply #9 on: June 30, 2022, 04:17:23 am »
Check the BIOS battery
  • Country: hr
« Reply #10 on: June 30, 2022, 10:45:16 am »
OK, the BIOS battery was a bit low at 2.5V, but replacing it did nothing exept resseting the time.
I got A BIOS POST card from a technician nearby, the code stops on 50 when it gets stuck
I tried different RAM configurations, and no changes.
The technician also gave me his testing GPU, and the system with the GPU installed never posts and gets stuck on 50 or d3.
It also stopped once on code 41 when I tried to unplug the GPU and plug it back in. And It might have stopped once on d1 with the gpu in alltough it might just be my imagination.
in the picture attached is the manual of the post card and the codes it gave me, not sure witch one should I look at.
Online wraper
  • Country: lv
« Reply #11 on: June 30, 2022, 10:53:09 am »
If it's intel CPU (LGA package), try cleaning its pads with alcohol. Also look for bent pins in the socket.
  • Country: hr
« Reply #12 on: June 30, 2022, 03:54:21 pm »
It is an AMD system, the pins look straight
  • Country: hr
« Reply #13 on: June 30, 2022, 05:36:10 pm »
After torturing it on the bench with a hairdryer, contact cleaner, forgetting to plug the cpu fan back in, it now starts every time.
I don't know what I did, but it works now.
« Reply #14 on: July 01, 2022, 12:05:39 am »
Hairdryer helped? If there are any electrolytic capacitors, check them for signs of leaking or bulging.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #15 on: July 01, 2022, 02:22:58 am »
Maybe it just wanted to be tortured.
iratus parum formica
The following users thanked this post: m k
  • Country: hr
« Reply #16 on: July 01, 2022, 11:01:26 am »
All the capacitors look fine and now it even works when cold
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #17 on: July 01, 2022, 12:23:28 pm »
I wonder if the drier blew some conductive debris that was intermittently making contact...
Also, always suspect the power supplies - sometimes they can lead to these annoyances if they are on the edge of failure, especially since their capacitors are subjected to a lot of thermal stress.
  • Country: hr
« Reply #18 on: July 01, 2022, 04:26:54 pm »
Could be the debre, but not the power supply, the power supply in the system has been recapped few months ago wheen I built the system.
I also Have 2 Power supplies I use for testing, it behaved the same across all 3 of them
