Hi again.
I'm looking at figure 6-1 in the hp1345a manual. As I understand there should be 6 H5 screews and 6 MP10 washers fastening the A1 board to the display enclosure. Probably they serve as groundpoints as well. U30 might need isolation. I haven't found that information yet. Sorry to say I only printed some parts of the manual
. Does someone know what sizes, materials these parts consists of?
I've started to think tearing it to parts to be asured of that none of the missing screews doesn't roll around on the main board. At the same time everything dodgy could be replaced as old caps, darkened resistors together with a general clean up of boards and connectors.
Addendum: the feet are missing that supposedly would fit into the 4 corners at the bottom of the unit. The rear feet are missing. Maybe some screews and plates are missing at the front of the analyser. Probably due to that the previous user found use elsewhere for the rackhandles or thought they have a value at the ePay... Who knows. Well I can live and use the instrument without those parts. Surely thought every hole will eventually get the right size torx.
Regards
