Author Topic: The thin material enclosing all wound nichrome wires  (Read 809 times)
Offline abdulbadiiTopic starter
« on: March 12, 2023, 06:22:01 am »
What is (and function of) this brittle thin material, if it's broken it'be a bit shiny white flakes, which encloses the wound nichrome wires in a heat element?
Offline Koray
  • Country: tr
Re: The thin material enclosing all wound nichrome wires
« Reply #1 on: March 13, 2023, 07:51:30 pm »
Do you mean mica sheets?
1737830-0
1737836-1
The following users thanked this post: abdulbadii
« Reply #2 on: March 14, 2023, 03:44:20 am »
So wonder if its other form, ie. small tube pipe has the same property, usefullnes
so just use this more sturdy kind, if it's
Offline DavidKo
  • Country: cz
« Reply #3 on: March 14, 2023, 10:37:11 am »
It depends how the tube is bonded together. That is why the construction shown by Koray is done. Another possibility is to use aluminum oxide.
