Author Topic: Thermal "socks" for MOSFETs?  (Read 1700 times)
Offline iXodTopic starter
« on: July 26, 2016, 04:26:58 am »
Never seen this arrangement of heatsink thermal pads:
http://imgur.com/a/ioVUr
What are the little "socks" that slip over the MOSFETs? And the aluminum shield between the sock and the large thermal pad?
Maybe modern replacement MOSFETs will have lower on-resistance and run cooler so I don't have to chase down new socks (these deteriorated during disassembly).
This is the control voltage supply SMPS in a '95-vintage bindery machine (sorts & staples).
Thanks.
« Last Edit: July 26, 2016, 04:49:19 am by iXod »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Thermal "socks" for MOSFETs?
« Reply #1 on: July 26, 2016, 05:55:42 am »
That's for creepage -- putting a lot of distance (and insulation) between high voltage (mains) and the heatsink (ground).
The shield tab is for, well, shielding.  I recommend leaving it in.  At worst, the unshielded EMI causes internal interference, skewing output voltages and frying the equipment (or interfering with other systems inside, causing malfunction).  At best, EMI emissions are increased slightly, and you (or your customer?) comes back later, with a C&D notice from the FCC (or other gov't organization).
So, you can use an over-sized insulator, of whatever material, or the "sock" and tubular kinds are still around.
Seven Transistor Labs, LLC
Offline b_force
    • One World Concepts
« Reply #2 on: July 26, 2016, 05:02:30 pm »
Seen these 'socks' a lot. I found them very horrible, they break pretty easily if you try to repair stuff.
Definitely not something I would rely on for safety creepage
Offline Kilrah
« Reply #3 on: July 26, 2016, 05:31:30 pm »
Just took apart my first device that had that a week ago. Have also torn the first one I removed when it was a lot less resistant than I'd have thought, then was careful removing the others and got them out in one piece.
« Reply #4 on: July 27, 2016, 02:37:42 am »
Are you repairing this? Where did you source replacement socks?
Thanks.
Offline batteksystem
  • Country: hk
    • My ebay store
« Reply #5 on: July 27, 2016, 04:27:52 am »
You still need the isolation, and the heat sink.
Probably you can get around with a simpler ceramic or silver mica insulation layer.
Also, if I were you, I will not replace with a different part number, especially in an SMPS.
If you really need the high thermal performance, get some aluminum nitride insulation pads. These things are AWESOME.
The ideal characteristics will be:
1. High dielectric strength
2. Non-flammable
3. Mechanically strong
4. Not brittle
5. Cheap
Offline Kilrah
« Reply #6 on: July 27, 2016, 06:17:37 am »
I only ripped a bit of it since I stopped pulling as soon as I saw it tear and it's on the front side so it'll still be good enough to reuse, I'll just fit it on a secondary side part instead of the primary one it was on for good measure.
