Author Topic: Thermal fuse  (Read 450 times)
Offline hamdi.tnTopic starter
  • Country: tn
Thermal fuse
« on: November 02, 2024, 01:01:02 pm »
Anyone can point out a replacement for this, I think it's a thermal fuse for 300°C. Google not helping much.
Thanks
Offline coromonadalix
Re: Thermal fuse
« Reply #1 on: November 02, 2024, 01:16:09 pm »
are you sure its a fuse instead of a cut off model   taobao  aliexpress  will show many, amazon too, many sites too
but this physical size / format    not so much
Online indeterminate
Re: Thermal fuse
« Reply #2 on: November 03, 2024, 09:21:02 am »
what did it cum out of
open it up , it looks like a self resetting thermal switch used for overload protection.
Online wraper
  • Country: lv
Re: Thermal fuse
« Reply #3 on: November 03, 2024, 09:36:07 am »
Where it's used? This manufacturer has part that looks very similar https://www.hcet-cn.com/products-detail-1049132 They also have HC02 model but it looks more different.
« Last Edit: November 03, 2024, 10:01:27 am by wraper »
The following users thanked this post: hamdi.tn
  • Country: tn
Re: Thermal fuse
« Reply #4 on: November 03, 2024, 10:40:05 am »
Hi all,  thanks for your help !
It's used on a hair straightener, to protect the heating element. It's marked "F" on the PCB and it's open now so I assumed it's a fuse. But it could be a thermostat that failed open.
Nice ! it certainly look like these,  thanks a lot  :-+
Online wraper
  • Country: lv
Re: Thermal fuse
« Reply #5 on: November 03, 2024, 11:22:08 am »
Then most likely it's just a thermal switch with no overcurrent protection
