Author Topic: Thermal Fuse Resistor  (Read 746 times)
Offline 2XTopic starter
  • Country: gr
« on: January 24, 2025, 07:04:47 pm »
Hello,
I have a thermal fuse resistor (at the below images) but I can't find it anywhere or some other similar. I removed the external ceramic material and inside the resistor is fine but the fuse is open. Also, I found the same thermal fuse. As I understand this fuse open independent of the current that passes inside it; if the temperature at the casing of the thermal resistor goes above 128Celcius it will blow up. How can I make something like the ceramic body? I found the below adhesive where is Thermally Conductive. I thought to put the resistor and the thermal fuse inside a heatshrink and fill it with this "8329TFS-25ML" adhesive or with some RTV silicone. Has anyone done something like this... do you believe is good idea or there is available a ceramic material for sale so I will make it as original was? Any suggestions are welcomed.
Cement resistor/10N40/10W40ohm/Vertical/1pc
https://www.11st.co.kr/products/1690272509
SDF DF128S
https://www.digikey.gr/en/products/detail/cantherm/SDF-DF128S/1014762
8329TFS-25ML
https://gr.mouser.com/ProductDetail/590-8329TFS-25ML
RTV162-85ML
https://www.mouser.dk/ProductDetail/MG-Chemicals/RTV162-85ML?qs=sbrGYOVz3HeDc3Zk7MUnMg%3D%3D
« Last Edit: January 24, 2025, 07:12:27 pm by 2X »
Online Audiorepair
Re: Thermal Fuse Resistor
« Reply #1 on: January 24, 2025, 07:22:12 pm »
What equipment is this from?
I have seen this before, so I am guessing it is in an audio Power Amp, my memory can't get further than that.
Point being is the thermal fuse really necessary?
The following users thanked this post: 2X
  • Country: gr
« Reply #2 on: January 24, 2025, 07:33:36 pm »
It is from the power supply of an old MMA/Stick Welder.
Just I want to make it like the original was and it is interesting to find a way to make it like the original. I use and a simple 40ohm/10W resistor and works fine... but for safety reason I beleive the designeer add the thermal fuse.
The following users thanked this post: Gyro
Offline Gyro
« Reply #3 on: January 24, 2025, 07:33:52 pm »
If the equipment manufacturer designates it a safety component, yes absolutely.
Best Regards, Chris
Online Audiorepair
« Reply #4 on: January 24, 2025, 08:53:47 pm »
It is not unknown for manufacturers to make stupid decisions.
In the case of an audio Power Amp there is little that can harm the user.
A welder is a whole different kettle of fish I don't fry, so I would go for safety.
Offline Gyro
« Reply #5 on: January 24, 2025, 09:05:08 pm »
(Slightly gobsmacked!)
It is not unknown for manufacturers to always know better than you regarding safety, especially after they have been through reviews and qualification. A 'casual' repairer introducing a fire risk can certainly harm the user!
If, as your username suggests, you repair audio equipment for other people, you should be following manufacturers' service information to the letter. If you are not doing this, you'd better have a bloody understanding public liability insurance provider, because worst case, they will throw you to the wolves.
Best Regards, Chris
Offline Haenk
« Reply #6 on: January 25, 2025, 02:15:04 pm »
https://www.mouser.com/datasheet/2/219/WF-10358.pdf
Maybe suitable? EOL though.
Well, seems impossible to find. Found 68R though.
Maybe go with a cement one and attach a temperature fuse to it; I don't think potting one yourself is possible.
« Last Edit: January 25, 2025, 02:26:25 pm by Haenk »
  • Country: gr
« Reply #7 on: January 28, 2025, 08:33:16 pm »
After some thoughts and experiments I ended in the below solution that the image shows. I used a thermal pad between the thermal fuse and resistor and tied them with a heatshrink. I also made a short circuit with connected 10ohm resistor after the resistor with the therma fuse that I made and the thermal fuse blow like it should. Also the device itself have glass fuses so I beleive it is a safe solution and closer to what the designer had designed.
Thermal Pad Part Number: COH-4065LVC-200-10
Offline Haenk
« Reply #8 on: January 28, 2025, 09:32:00 pm »
Yep, that looks like how it should be (as a replacement).
I don't think the exact temperature of the fuse is important, just the "about" range should be the same.
Offline Whales
    • Halestrom
« Reply #9 on: January 28, 2025, 09:50:20 pm »
Fire dude, fire.
Offline Simmed
  • Country: nu
  • im not not not from Niue
« Reply #10 on: January 28, 2025, 10:30:54 pm »
i think heat shrink long term exposure to heat = cracking
so the heater will decouple from fuse and you get a new failure mode, maybe something else will burn this time ?
The Niue Star is a monthly Niuean newspaper. Its founder, owner, editor, journalist and photographer is and has always been Michael Jackson.
  • Country: gr
« Reply #11 on: January 30, 2025, 11:58:21 pm »
This fuse is only for the startup and for the inrush current that the capacitors draw. It is in use for some miliseconds when the power supply is turned ON and then a relay where is in parallel with the resistor activated, so the fuse will be heat only when there will be a problem on power supply (a shortcircuit) and consicouently the thermal fuse will blow out. If the thermal fuse is all the time in use and heated the heatshrink propably will crack (this also it depends and from the temperature that its heatshrink can withstand).
Offline Geoff-AU
« Reply #12 on: January 31, 2025, 03:19:34 am »
To me, it sounds like the resistor is there for inrush.  The fuse is there so that when the relay fails (electromechanical device, finite switching life) the thermal fuse will detect that the resistor has stayed inline and open the circuit before things get too hot.  Resistor wiring will glow white-hot before it fuses, so the outside ceramic surface will be dangerously hot if the overload is a slow one.  The thermal fuse is there to protect against fire.  Check the health of the relay!  And also for inrush duty, the thermal fuse can likely be lower value like 60 degrees. 128C is a perfectly fine value, wouldn't want to go much hotter though.
Counterpoint: you don't know what you don't know.
