I am currently facing an issue with my rice cooker, where the thermal fuse has been triggered twice, leading to a disruption in its normal operation. I am reaching out to seek your expertise and advice on identifying the root cause of this problem.
To provide some context, the thermal fuse serves as a safety device by opening circuits when the temperature exceeds a certain threshold. I understand that it can detect heat caused by overcurrent due to a short circuit or component breakdown. In my rice cooker, I have identified three key components: the Heating Coil (for cooking), the High Resistance Coil (for temperature maintenance), and the Magnetic Temperature Switch (which opens when the set temperature point is reached).
I believe the internal configuration of my rice cooker matches the diagram shown in this video:
https://youtu.be/dZxdVCHAAsA?t=124Additionally, I have attached an image of my rice cooker, highlighting these three components for your reference. :
https://ibb.co/ZBfJcsKThe thermal fuse's specifications are as follows: SEFUSE - SF188E - JET192ºC - (PS)E10A - CCC 250V - C1632. You can find more information about it:
https://media.schott.com/api/public/content/ff224fc379ec4eb09a770a547ac50b04?v=37aaf3af#page=6&zoom=180,-102,564Despite changing the thermal fuse twice, the issue persists. The rice cooker operates normally for approximately 15 minutes, and just before the Magnetic Temperature Switch opens (indicating that the set temperature point is reached), the thermal fuse is triggered.
I am eager to troubleshoot and identify the specific component causing the thermal fuse to trip. Could you please provide guidance on tests or diagnostics that I can perform to isolate the problematic component?
