Author Topic: Thermal insulating pads: Replace every time, or re-use?  (Read 595 times)
Offline cvancTopic starter
« on: July 30, 2019, 03:43:03 am »
I've always replaced them, even when they looked fine, but I wonder if I'm being more conservative than I need to be?  Is it really necessary to replace these every time?
What do you do?  Thanks.
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Re: Thermal insulating pads: Replace every time, or re-use?
« Reply #1 on: July 30, 2019, 04:47:38 am »
Depends on how lazy I'm feeling and how critical the part is.
Vreg for a relatively low power PSU? usually reuse if it isn't too old. Expensive ASIC or FPGA or other esoteric or critical part? New pads all the way.
Sometimes I'll add a tiny bit of thermal paste to each side of the sil-pad too, it helps stick things in place while I fumble around with the mounting screws etc.
